Antler Turning?
WoodWrangler
Jeremy
Our good friend Phillip (ptt49er) hooked me up with this piece of antler found on his property (I think that's what he told me).
I've been wanting to turn antler ... but where to start? I hear it turns well.
Do I just turn it between centers, wobbly and all? I assume it's safe to cut with my bandsaw blade for wood?
Advice welcome.
I make buttons and flint strikers with antler. Never turned any.
I saw it with a hack saw but a band saw should work if the teeth are fine enough.
Drill with regular high speed steel drill bits.
I think the pen folks turn it on a mandrel, but centers should work.
What are you going to make with it?
I've turned a couple pens, yes you can cut it on the band saw, it's hard to get the hole in the pen good due to the curve of the antler, but can be done, just have to make sure theirs enough meat around the hole. It turns great, but make sure your chisels are sharp, it might have some voids in it, fill with thin CA. Smells a bit when turning, but not too bad. Take it slow at first until you get it round.
There are two way you can go about it. One is to turn it between centers till round and then drill it. This method will probably result in exposing mostly the "marrow" which can be interesting, but looses a lot of the "antler" feel.
Another method that I've learned from Eagle RIP is to clamp a section of the antler in a Bessey type clamp with just a little sticking out the side. Run that through the BS to get you a relatively flat face. Then rotate it 90º and cut another flat face. This will give you two reference surfaces to put into a pen vice and drill it. Advantages are you can chose to leave some "bark" on the blank by cutting to one side of center. This is particularly good with a very thick section like you are showing. I generally chose thinner antler to turn so you are closer to the final dia and can preserve some of it's outside characteristics. Of course this is a double edged sword. Thinner, younger antler don't have the "bark" characteristics of and older piece like you are showing.
Either way, be ready for a smell that is totally unique. Put a fan behind your back if you are the squeamish type, or put on that space helmet that you have.
Pen - mainly "marrow' -
With "bark" -
MTCW,
Gerald
Gerald
I have turned several pens with whitetail deer antler and one with a piece of moose antler that I bought in Maine while on vacation. It turns very well with sharp tools but you are correct that the real problem is drilling through the antler to mount the pen tube. I finally made a little wooden base for my drill press and screwed a small machine screw up from the bottom so just the tip of the screw stood proud of the table base. I then secured the base to the drill press with clamps and centered the drill bit over this screw tip. I made a small indentation in one end of the antler segment and placed it on the screw tip. I hold the antler with a set of pliers and start the drilling at the top of the antler segment. Since you centered the drill bit over the screw tip, the drill has to go toward the screw tip as you pull the drill head down and eventually drills all the way through. Sounds complicated but it really works very well. The smell is a bit nauseating since it smells like a dentist is drilling out for a filling. Good luck Try to select an antler segment that is about the size of your finger so that you will have some bone around the hole.
MrAudio815
Matthew
Wow,
That is awesome I never new you could do that. Dave, can I do that on the HF lathe? What tools, will I need? And I should have keep my spike antlers! Arg!
I love this site, such talent, such imagination!
Sir Chiz
Phil
I've turned some deer and elk antler, also beef bone, usually start between centers to make enough tenon to hold it with pin jaws and drill for pens and key fobs.
For other pieces, I just grab it with the pin jaws and center best I can.
Elk was a lot of marrow with a thin shell, required a lot of CA.
Deer
Elk
Deer antler is the whiter pieces, the yellowish is beef bone.
Phil.
Hi Phil!
Great to see you posting!
Any chance you would show some of the tools used on those tiny pieces? I like making miniatures but have a hard time making the tools. I mostly use old dental tools and regrind them.
PChristy
Phillip
Dave and Phil those are some great looking turnings:icon_thum - I really do like those:eusa_clap
ptt49er
Phillip
If you want a smaller piece to try Jeremy I've got two racks. I can probably get some more if the need arises. I just need to turn a pen or two before I start barking up that tree again.
Phil, it's great to see you back on N.C.WW!!!
gator
George
Here are some antler/.308 pens from a year or so ago.
These were on my craft show table, the colored dots indicate price and the white slips are a description of the pen and refill information.
George
Wow,
I made them on the HF lathe, I am sure you can too :icon_thum. A spindle roughing gouge and scraper or skew chisel is all you need. A buddy of mine gives me all the sheds he finds on his 100+ acre farm where they have been managing the deer population quite well.
Sir Chiz
Phil
Thanks for the welcome Folks! :embaresse
Aside from a Crown 1/4" skew and gouge, I make most of my tools from masonry nails, $3 for a box-o-tools, :wink_smil also use a 3/16" metal lathe bit ground to a sharp angle and point for part off. The long angle and point allows undercutting when parting off, and leaving almost no knub.
Here's some tools, nothing fancy,skew, hollower,hook tools and parting,
Phil.
WoodWrangler
Jeremy
Phil.
Now ... that is cool!:icon_thum:icon_thum
MrAudio815
Matthew
Sweet! I can't wait! I was sure hoping it could do that. Thanks Dave.:icon_thum
Now to find some people with antlers!:gar-Bi
