I havent posted in awhile so I thought I would post a WIP.
I am doing a open segment turning, what James calls a snaggle tooth turning.
Gluing the first ring on, showing the home built gluing platform.
A close up of the business part, with a special built stop block :gar-La;
And a picture of the homemade index wheel, this one has 32 indexes , a bit rough but it works just fine.
The second ring glued on, even though each piece was thickness sanded and the top looks flat and smooth, its not good enough to glue the next ring
So I mark each segment with a pencil.
And after the glue has set for at least 15 mins. then hold the sanding stick on it, its not spinning in the picture but it is spinning while I hold the sanding stick on it, LOW SPEED
And now it's dead flat and smooth ready for the next ring, of course this is done after each ring even though I didnt show it after the first ring
Thanks for looking
Just hope someone enjoyed it.
Thanks for looking
