i need to turn two matching shaker style knobs in walnut. i did some test knobs in scraps and settled on sizes and have dividers set up to produce a few. i'm still having trouble getting them exactly the same. as much as i want to make this myself i am tired.
does anyone have a process for repeating turnings? i need a new approach or i may be ordering something from the internet.
also, I want to use the knob shaft in a jacob's chuck in my head stock to do final sanding but that limits by shaft size to 3/8 which seems small. i've seen Roy turn a taper on the shaft and stick directly in the headstock but i dont have a taper reamer. any other suggestions for holding the work in the lathe so it can be finish sanded?
thanks in advance.
bh
thanks in advance.
bh
