A couple years ago I dumpster dove a building directory from a project I was doing. I always knew what I'd do with it, and finally this spring I did it. It is an aluminum frame with about 6" of depth and an acrylic cover (hinged). So. I got me a bundle of 1" thin wall PVC pipe and a couple bags of tees, some elbows, and adapters, and some black paint. Cut some 2" Styrofoam I had for backing, & 2 hours later, voila! I had a solar water heater for my pool. LOML likes the water warmer and this gets her in sooner. It was hooked to a sump pump with water hoses and put on a timer. It will raise the water about 4+ degrees on a pass on a sunny day.
Well, on Thursday, Murphy took over. This is what it looks like after the GFCI tripped out that morning and the water got a little warm:
Ironically it still works, & with the pipe flattened out it probably gives more heat transfer than before. I think I'll leave it this way for awhile.
