As I was researching how to make a jig to cut the notches, I stumbled on Mortise and Tenon joints.
As for my shelving in my office, I am going to stick to my 2x4 plan because I want it to be a bit more industrial looking.
Thank you very much for the post and all the pics & info. Those look great. I wish I would have seen your post before I built shelves, etc. for my daughter's closet. I bought some "blonde wood" at the big blue box. I am guessing that is their version of whitewood. Anyway, I did not realize that only 1 side had a thicker veneer. I found out when I started sanding and the other side looked like...well, you know. Afterwards, I found they sold some 3/4" maple that is supposed to have the same thicker veneer on both sides. The Blonde was $50/ sheet and the Maple is $53. Not sure how that compares to "cabinet grade plywood" or if the maple is cabinet grade.For the cabinet sides, supports, trim supports and shelves, I used 3/4" paint-grade maple plywood from Rugby in Kernersville, and 1/4" paint-grade maple plywood for the back. Cabinet grade plywood is SO much nicer than "whitewood" from the big box stores, and is actually less expensive!
