I wanted to make a couple bar stools out of oak and found some pictures of a chair I like. The chair was designed by Vidar Malmsten of Sweeden many years ago. I emailed a couple of schools that have classes and plans for making them, but they were not willing to share. Since I wanted a bar stool height anyway I figured I was on my own. I drew up some rough plans at this point and started making the rear legs since they were going to be challenging. Being curved and tapered they could be cut from a solid piece or laminated.
Inspired by Mike Davis’s design of curved tapered legs (table in his case), I discussed it with him and decided to give it a shot. The trick is to make thin strips narrow on the ends and thicker in the middle. Mike made a fixture that hooked up to a vacuum to hold the strips on a curve so they could be cut on a table saw. I decided to try using a thickness planer. I made a sled by mounting a 1/2” thick board onto a 1” piece of plywood. After determining the thickness required at each 5” interval, I then put shims between them as required. Since my strips were narrow on the end, there were no shims in the middle and gradually increased towards the ends. The bottom of the leg is thicker than the top so it’s not symmetrical. I used 2 face tape to secure the strips to the sled. Much to my surprise, it worked pretty well.
Sled with 3 or 4 strips at a time .
Sled at bottom, shims, sled board, 2 face tape, strips for legs.
Leg clamping fixture.
Leg.
To be continued…
Leg.
To be continued…
