Oak Stool / New Design
MLB3164
Marty
Saw this design online and did my version. Made from Oak cabinet fillers.
iclark
Ivan
Very interesting design.
How did you couple the lower step with the taller verticals? Since the front of the upper step is not over the base of the taller verticals, it looks like there will be a rotary load on the connection between the taller sides and the lower step.
Henry W
Henry
Made me curious too. A close look (increasing size of picture on my computer monitor, not phone) helped me see what I think is a screw hole and plug or a dowel inserted through the vertical to the back edge of the lower step. The area is a bit lighter than rest of the vertical, and this looks to me like this was spot sanded and not yet wiped clear of the sawdust/swarf.
So my guess is a screw or dowel there. We'll see once the Marty (OP) answers with the real truth (not my guess).
MLB3164
MLB3164
Marty
Here is a pic marked in red where I used dominos for strength. Henry the light area you mentioned mid way down the long leg is where I forgot to set the domino depth and went completely through the side, domino plugged, flush cut and sanded smooth. I am still learning the domino and all the settings. Ivan on my version I made the long leg more vertical to hopefully reduce some of the torque effect standing on the top step. This is NOT a stool I would make to sell and only maybe give to people who weight under 150lbs :p:) and sign a release of liability......
Henry W
Henry
Domino, dowel or whatever.
And yes Domino settings are important to get right - not that I have ever made that sort of mistake - Nope, I will forever deny it and certainly never show a picture.
iclark
Ivan
Marty,
Thanks for the explanation/info.
It looks like it would be a great stool for a kid to use to brush their teeth at a sink with a vanity.
I was thinking that it was for heavier folks (like me) because of the support/stiffener under each step.
MLB3164
MLB3164
Marty
Marty,
Ivan I am 250lbs and it has held me every time I have climbed aboard. I am going to keep testing it to see how long it lasts. I mainly put the pieces under the steps to break up the lines a little. Wait to until you see my next stool I copy, another engineering feat.
MLB3164
MLB3164
Marty
Marty,
Thanks.
I look forward to the next one, too.
What do you guys think? Bridal joints strong enough? I think the guy where I found this sells these stools.
Just an FYI I have not built this one yet. Stolen pic from the internet. :cool::eek:
Charles Lent
Charley
Marty,
i like your stool, and the design of the other one that you posted in the 2nd photo, but I think both need a smaller leg footprint. With large legs contacting the floor there tends to be too much wobble when placed on imperfect floors, like in older homes. For the one in the 2nd photo, I would move the cross piece between the legs up to the bottom of the 1st step. I think I would also increase the surface areas of both steps. It does look like a very sturdy design, although somewhat difficult to make due to the joint designs. These are just suggestions. I would not hesitate to but my 229 lbs on either stool. They both look sturdy enough to last another century or two.
Charley
Henry W
Henry
Marty,
Charley
Taking off on CHarley's idea on the 2nd piece, I might suggest cutting a gnetle arc in the bottom of the cross pieces to reduce footprint. I see the bottom step already has a saddle joint from the step support right below the step, so miving the cross piece up complicates the joinery.
MLB3164
MLB3164
Marty
Thanks guys, great input and suggestions. I had never thought about the long footprint being an issue. I might make the bridal joint stool from a lesser wood in case it doesn't work out.
Jack A.
Jack
Yes, bridle joints are strong enough, as long as your wood is up to it. That example looks like oak, which is plenty strong.
For a design like the one with the bridle joints, you can add feet to deal with uneven floors.
In your original design, do you have any bracing across the grain on that bottom step? If not, adding feet may be a problem; it it would make that bottom step want to crack at the joint between the front and back legs.
MLB3164
MLB3164
Marty
Once finished I am only going to use felt strips on the legs of the original stool in this post. I agree adding "feet" could create too much stress on the whole design. Thanks for your info.
iclark
Ivan
Felt strips under the legs of the original stool sounds like a great idea. If you use a thick felt, it can accommodate a significant amount of unevenness of the floor.
The bridle joints are plenty strong enough for the 2nd one if you use 8/4 lumber like the one in the pic. I might be worried about using the design in 3/4" thick (or thinner) lumber.
I think that Henry has the right idea about reducing the floor contact of the spreader to just the foot areas by adding a gentle curve, scallops, or an architectural shape of your preference.
