Very small laser
Is there a reliable small laser that is simple to program and operate for burning my signature into a spoon handle or bowl?
chris_goris
Cheap and easy to program!
NOTW
Notw
From my experience the small lasers typically use a software call LightBurn to control the laser and create the artwork. A couple of youtube videos and I was up and running. My "laser" is a bit unique as i bought the laser module from Creality that attaches to my 3D printer
I have a branding iron. It will not work on the curved surface of a spoon handle. I would need several sizes to work on different products. Also would need several more to burn the wood species and date/year. I was looking at X-tool for $600. says it can run from my phone.
riggsp
Phil
X-tool model F1 is a very portable and fast laser engraver...I watched a demo of it at the local Woodcraft store a few weeks ago...I won't call it cheap at $1599.00, but it would easily engrave your spoons and much more.
Echd
C
I've got an older "20 watt" (Chinese companies lie) Ortur laser master I'll let go real cheap if you want it. I have bigger lasers now and do not use it. It will do just fine for what you have in mind, and is not large. It needs to be connected to a laptop or pc to run. I believe the work area is 400x400 (they use heathen units). I'm in rockingham county.
WallNutz
Bryan
I have an Ortur and it does ok for my needs, but a curved target will diminish the quality due to the changing distance between the laser and the wood. For curved surfaces you'd need a rotary attachment. Perhaps the machine you're looking at offers that capability.
The attached photo shows what happens if the target is not completely flat relative to the XY plane on which the laser moves. Notice the left side is much crisper - that's the side I used to set the laser focus.
If you're burning a single small font into the center of the handle or bottom of the bowl, the quality degradation may be slight enough to not even matter to you.
Thanks but I don’t have a computer. Only my phone and iPad. I use computers all day at work and don’t even want to see one when I get home.
smallboat
smallboat
Ive done some laser engraving of pens without a rotary attachment.
with the copy going parallel to the long axis of the pen (similar to Mike’s spoon image ) there wasn’t an issue with focus.
I could do multiple lines of copy with a little jig I made that indexed the rotation around that axis. - engrave, stop, turn, engrave, repeat…
Just one line in the center of the handle along the axis. Worst case maybe 1/4 deviation from planar.
