Very small laser
Artisan Pirate
Artisan Pirate
I watched your video. I don’t like videos because they cause me to have more questions than answers. I really need to take a few spoons and bowls and see the process and results.
totally Understand, I know Mike Matthews had a 10w laser thats also a Longer I believe
mkepke
Thanks but I don’t have a computer. Only my phone and iPad. I use computers all day at work and don’t even want to see one when I get home.
Given this and if all you want to do is sign your work, consider a woodburning pen instead of a laser.
80-90% of CNC work is the computer-side of things. The actual CNC machining is the 10-20% remainder.
-Mark, who was in the shop this evening running calibration test patterns and materials tests on his laser.
I have a Colwood wood burning set. I used it for years, it takes time, is not consistent, looks bad to me. That’s why I bought the branding iron. Branding works great for bowls and flat work. Doesn’t work for my spoons. Also it would be nice to add the year and species. I heard or read that some lasers can be programmed from a phone or iPad.
One of the guys at work has a Longer brand laser. I’m going to see if he will show me how it works.
mkepke
Far be it for me to talk anyone out of a new tool :)
If you want I can give you a remote tour of my set up. I think my it’s pretty typical for a hobbyist.
-Mark
mpeele
michael
Here you go, meets all you requirements except I could not find lense focal length but it's probably short since is promoted as an engraver and not a cutter :
Less than $500 and no computer required.
Without a rotary you will have to have a long focal length lens. A 3" lens will give you a good 6 mm depth of field but the spot size will limit the sharpness. An engraver typically has a very short focal length which will maximize power and detail.
I think to do what you want to do you'll probably spend about $1000+ and invest a fair amount of time to get set up to do a quality engraving.
