Veneer glue for humidor?
N00B
Hey, everybody.
I am making a small, desktop humidor. The sides are made of spanish cedar and the top MDF. I am adding rosewood veneer on the outside. I was looking at titebond for veneer, but in the product specs it says not appropriate for high humidity. What glue should i use?
Thanks,
AL Spicer
Al
Jeff,
I use Pro-Glue on all my veneer work. I dries hard and you must follow the instructions. it will not work below 70 degrees. For below 70 I put a electric blanket on it. Be sure to veneer both sides for stability.
http://vac-u-clamp.com/adhesivesandsofteners
Urea Resin Wood Glue - A modified pre-catalyzed dry powder resin available in a light or dark color, activated by mixing the powder into water.
Good luck,
Al
