When I want to turn a bowl at the end of the lathe, it is necessary to remove the tailstock assembly. Not only is the assembly heavy, but it requires space to store it after removal. There are several commercially built solutions, but not only are they expensive, none of them meet my criteria. I don't want to add permanent length to the lathe bed. I also don't want to swing the unit 180 degrees to the back side of the bed because it will be in the way of a steady rest. The following photos are the results of 3 hours of work and $7 materials (hinges and bolts, I had the MDF and hard maple). The unit folds under the lathe bed extension, utilizing unused space. It takes about 10 seconds to remove or install the tailstock assembly. Note: The design will only work on PM3520's with the optional 18" bed extension.
Tailstock assembly in normal position and removal unit (black box) in stowed position.
Hard maple and MDF removal unit in position. Note the u-shaped channel which prevents the tailstock assembly from sliding off the removal unit.
Tailstock assembly slid onto and locked to removal unit.
Note: Prop stick is only for photograph purposes.
Assembly/unit in swing away position.
Assembly/unit in locked position, totally out of the way and utilizing unused space.
Swing clip that locks assembly/unit in place.
