Photo upload selection for Linux users......
froglips
Jim Campbell
The new flash uploader works like a charm!
Only issue I found was upper case filenames. FILENAME.JPG files are not seen, whereas FILENAME.jpg is seen in the file selection window.
Odds are its a Linux user issue, which probably only affect me and ashley_phil :)
I'll work on this one.
I'm running Firefox on Linux.
UNIX just turned 40, so its only fitting a filename case issue comes up :)
NCPete
Pete Davio
have fun Jim, I am only an occasional user of Linux now, but have an old laptop I will probably be 'repurposing' for use at work with a fresh install of Ubuntu. I will let you know when that happens, and gladly try to break things with it, if you need some help.
froglips
Jim Campbell
The problem lies with Adobe.
They don't work with Unix filename case. The only known fix is to add both upper and lower case filename extentions to the list.
For now, I've only added ".JPG" to the list. Anyone on the Staff can add to the list in the Photopost Admin tool.
Thanks,
