This cabinet is inspired by some flip-top cabinets I've seen on the web. I wanted something like Slambubba's cabinet (which comes from one of the Wood Magazine "Idea Shop" plans).
The main thing I don't like about that design is that you're limited to only two big tools. Because the cabinet has a back panel, you can't have a tool on the other side of the flip top, or you wouldn't be able to "flip it". I wanted a cabinet to hold three tools, so that design really wouldn't have worked for me. If one of the rotating panels has a tool on the other side, you'd have to either leave the back panel off (less stable), or make the depth of the panel much wider to provide clearance (thus greatly increasing the depth of the cabinet).
An alternative approach is to design the cabinet so there is no back panel. That way you can have a tool on both sides of the top. I got that idea from pconroy's cabinet.
I thought that if you made a double-wide cabinet like that, it would be too unstable... maybe not, but I thought so. Regardless I was afraid to try it.
So anyway, I got the idea to combine the two concepts... sort of. I just turned the axis of rotation 90 degrees. That way I could make the panel that holds two tools WIDER to give clearance for rotation, without making the whole cabinet a lot deeper. Hopefully that makes sense... well, here's the pics:
It works well, and it's pretty darn stable. And it's even kind of fun to flip those tops over! :eusa_danc I plan to make an elevated platform on the left (smaller) top to provide an infeed support for the planer. Then it's just a matter of applying a finish.
The biggest problem with this cabinet is the same for all flip-top cabinets - you get the convenience of a versatile worksurface without breaking your back changing out tools, but the storage space inside the cabinet is sacrificed. Of course, only time will tell if this design holds up, but so far it seems good.
There are more pics of the construction details and progress in my gallery.
