At Insomniac's suggestion I am posting this. He thought some of you (DavidO?) might get a kick out of it.
In the following project completed a few years ago, I tried to combine into a single piece- a storage box and a work base for my Leigh D4 dovetail jig. I tried to build it so the jig would not need to be removed from and actually stay bolted to the storage case- and something that would be quick and easy to use. The case is the work base and raises the jig to a comfortable height above he bench to use the the router and jig.
The box is made from birch ply. The bottom of the case extends past the sides of the box so the assembly can be clamped to a workbench. It works well. I need to get some better latches. The pics are pretty much self explanatory. I used cardboard templates to play around with and verify the geometry and operation of the box before cutting any ply.
The biggest drawback- unfortunately, due to the size of the jig, resultant box size, and the fact that I used 3/4" ply- this thing is heavy!!!! Oh, well, it was a challenging design project.
I have too many other things to do before I put this case on a diet. When I and if I do remake the case, I will likely add a bit/parts drawer to the front of the rotating base beween the rectangular openings.
Closed storage case:
The front unlatches and drops down to expose the jig (which is mounted upside-down):
The jig and part of the case top rotate (pivot pin is next to the carrying handle):
And rotate:
The jig ends up on top:
The front of the case, once closed and latched, supports the front of the jig base (case top)
And rotate:
