I'm making some end tables, and want to try loose tenon joinery. My math isn't that great, but 8 mortises in the legs and 8 in the aprons, times three tables, let's see, carry the one, drop the chisel...well that's a whole lot of mortises.
I've done the drill press/ chisel thing when I built my workbench. Works OK, but it's slow. I've made a simple mortising jig for a plunge router that works OK, but I'd want to redo it to make it a little easier to use, more accurate etc. Building good jigs takes time and the materials aren't cheap, even if you're using using plywood, T-track and knobs.
I looked at several commercial solutions. Keep in mind that my volume of projects is pretty low, and my shop is already full. A Domino would be great - accurate, small, fast, but it's not exactly cheap. The Woodrat seems to be ideal for all sorts of joinery, but there's space and cost. I also looked at a dedicated hollow chisel mortiser, but it's another machine in the shop, and there are chisels, vices etc. to consider.
There are a few interesting jigs out there, such as the Mortise Pal, Trend MT jig, Leigh FMT, Beadlock Pro and the Dowelmax. Of these, the Mortise Pal and Trend MT jig appear to be a good balance between features, size and price.
So, what do you use for mortises? What do you like/ dislike about your current method (accuracy, ease of setup, speed, space needed, dust collection)? Ever built an adjustable jig that wasn't quite as useful as you thought it would be? Any experience with a commerical jig?
