HF Dial indicator and magnet base
fsdogwood
Pinwu
Saw the latest HF sales online, that its dial indicator and magnet base
is on sale again:
and
Good for machine setup.
HTH.
Pinwu
Heading that way over lunch to get it, and maybe the $7 turning set...to re-grind into tools that I need, if it's worth the $7 :eusa_thin
sapwood
Roger
Yep, that's an unbeatable deal! I've been using the HF base and indicator for over a year and love it. :icon_thum Just don't buy the moisture meter :BangHead:
Roger
Now you tell me about the moisture meter :eusa_doh: I bought it a while ago and it worked for a little while and then quit even after a battery change:BangHead:
HF is a dangerous place for me, I went in to save some money on the dial indicator and mag. base and walked out almost $90 poorer with almost 130 drill bits in tow...they just begged to come home with me :lol: :lol:
fsdogwood
Pinwu
Usually HF is good at letting you return/replace stuff that is not working,
you may want to give it a try.
For that $7 turning set, I don't know. I have a HF wooden-handled chisel
set, it's cheap, but the chisels (especially the wider one -- 1") won't hold
an edge. They might be good candidate if I want to learn hardening them
myself.
Regards.
Pinwu
Unfortunately I no longer have the receipt for the moisture meter, and had it for several months before I found out it was a dud...chalk it up as one of life's lessons. The $7 turning set was a joke, I wouldn't even get it to re-grind the skews into specialty scrapers :roll:
Tarhead
Dave,
You really have to push on it to get the switch to activate. Much more force than you think you need (or it will take). Touch it to a piece of metal and see if you get a reading w/a fresh battery and push the points into a piece of wet wood you know is not dry and see. There is a spring loaded switch inside that requires a fair amount of force. The CLT store manager gave me an inservice after I returned 3 of them.
I was just playing with mine, and it is exactly the same as what Lee Valley is showing :eusa_danc :eusa_danc
