First a couple disclaimers:
I ordered on Wed, it arrived on Fri. Wow! I paid for lift gate service and the UPS guy used a pallet jack and dropped it exactly where I wanted it in my garage.
Assembly:
I did not have a mobile base ready so I left the saw on the shipping pallet (the small one it is bolted to, not the larger one).
Overall the process was very easy and all the parts were there. They also package the bolts you need along with the parts you are installing so there really isn't any guesswork.
First you unbolt a shipping brace on the motor (nice looking motor!). The bracket is held on the motor by a cotter pin through a bolt. After you take the pin out you can slip the brace off. The instructions tell you to replace the pin. Very odd though... there are these two beefy bolt holes to hold the motor on to the trunnion and one uses a bolt and the other is just pinned, no bolt. This didn't seem right...
After that there really was little drama. The hardest part was putting the rectangular steel tube onto the rails. That bar is heavy and they greased the snot out of it.
I had the saw up and running in ~2 hours. However I had not dialed in accuracy or attached the tape on the fence rail.
Parts quality:
The motor is powerful and there is not much vibration (although there is more than I would expect, this could be due to leaving it on the pallet which is not very sturdy).
The power switch is very easily switched but is otherwise great. It is in the perfect place to turn off with your leg.
The miter gauge is nice enough. It destroys the old one that came with my Jet contractors saw. You can adjust out they play and the stops are positive.
The main table is very finely ground. Great finish. The extension wings don't live up to the main table. They are not as polished and have some tooling marks left on them. Also the castings themselves are sorta grungy on the bottom. But after a couple coats of wax I don't think it matters a bit.
Now for my first negatives. I would be disappointed if I had paid for a powermatic and received these parts. My laundry list of not-so-goodness:
No cosmoline on the main table.
One of the handweels looked rusted/pitted. Turned out to be something that can be cleaned off but I lost interest after rubbing for 10mins:
The paint on the rails was peeling in some places where it transitioned into unpainted surface:
The rail has random scratches all over the finish (the Biesemeyer I previously owned had a pattern that looks like it was milled, this rail it just looks abused):
There was rust on a couple screws:
- This is the first cabinet saw I have owned. I have however owned contractor saws.
- I have only had the saw for 2 days. This is not meant to be an in-depth review.
Assembly:
Parts quality:
