I have been using pretty much the same finishing schedule for the past six years or so and run into a perplexing issue.
It is all constructed with QSRO.
I was making raised panels for a project and decided to prefinish. I sanding the face of the panels (front and rear to 180 G and the outside bevels to 200G. I then applied 1 coat of Minwax oil based stain. I assembled the case and proceeded to stain the rest of the carcass. (top, rails, stiles etc.
When I added the wipeon poly, the face of my panels developed a white chalky appearance and seemed to eat through the stain.
Here is a picture of a couple of the panels......
On advice from Howard Acheson the inside of the case (panel backs) I topcoated with dewaxed shellac to knock down the odor from the stain and poly and don't see the issue...
Likewise. All of the rails, stiles and the top of this case are fine with the same finishing schedule?
Both the stain and the satin wipeon poly are out of brand new cans that I kept in the house until finish time. The temp. in the shop was around 62-65 degrees.
If anyone out there has encountered this type of an issue, your advice relative to repair sure would be much appreciated!
Feeling down and beatin'!:dontknow::icon_scra:BangHead::BangHead:
Thanks in advance for your input.
