Feature ring how I do it.
erasmussen
RAS
My way to make a feature ring.
The finished ring rough turned.
Starting with a block of Maple and a print out (a circle divided into 16 parts)
Pattern is glued on the wood and I will cut into 16 pieces to make 2 sun's
Sanding each piece
And gluing the rays in
Cutting plugs to make the sun
Clamping 2 togather with a thin spacer between them and drilling then
Gluing the sun piece in 2 at a time
Of course cutting them apart
After cleaning them up on the sander then cutting the angles to make segments of them
The ring dry fitted before glue up.
Glue up
After flatning and sanding one side glued on the turning
Thanks for looking
MarkE
Fantastic! :thumbs_up:thumbs_up:thumbs_up
Thanks for walking us through your process.
cskipper
Cathy
Your work is so amazing, you are really mastering the process!!!! :eusa_clap:eusa_clap:eusa_clap
WadeP
Wade
Step 1: I look at the pictures
Step 2: Amazed!
Step 3: Know that such works of art will never come out of my little shop.
Very nice. Thanks for sharing!
Wade
I think every ring in that form is a feature ring...but the top one definitely takes the cake! Incredible.
