On Friday afternoon, I finally got my AC unit mounted in my shop. I have had the unit for two years. Last year I made the thru the wall sleeve, but couldn't seem to get enough time to install it. After the installation on Friday, I found out that a 5000 BTU unit is too large for my shop. The unit quickly cooled my shop down to 69 degrees. It was 78 degrees before starting the unit. But I needed it more for the dehumidification than cooling. Due to insulation in my shop, the unit doesn't run long enough. My shop is 24' X 28', with R-30 / R-19 in ceiling, insulated roll up doors, and 1" thick foam sheathing on the walls. It is also located under shade trees. In order to get rid of humidity using AC, I could "kill hogs" in my shop. I guess I will have to run dehumidifier to get rid of the moisture, and run AC to get rid of heat from dehumidifier. At least my shop is COOL, even though it is still humid.
