Zinsser Bulls Eye Spar Varnish...
Not happy with it. The dry time is excessive. I am making some replacement thwarts for my Father's canoe. I bought the Zinsser product because it was a little cheaper. The can says a dry time of around 4 hours to re-coat, at the proper temperature range and humidity level. Well my shop is at 70º and 35-40% RH. 12 hours later this stuff is still tacky. The first coat applied took almost 72 hours to dry to the point of not being tacky.
I have used Minwax's Helmspar Spar Urethane in the past with great results, I guess I shouldn't have tried to save a buck or two :BangHead::BangHead::BangHead:
Could it be the difference between a Spar Urethane and a Spar Varnish :dontknow:. Both have the same application instructions, but the Urethane formulation seems to be much better.
MTCW,
I'm curious, what species of wood are you using?
Beech, not an oily or extremely dense wood I think.
I'm still tacky after 24 hours, which is the stated full dry time. I applied full strength with a foam brush. The pieces are hanging vertically from the ceiling. I tipped off to the point of no runs or drips so I don't think my application was too heavy.
There is a series of numbers on top of the can, part of which could be taken as a manufacture date :dontknow:
L70011 07614 7 270 01D
That could mean that this can was made back in mid June of '07.
I would love to get another coat on and dry by Friday, but I don't think that this is going to happen. So I will just have to be happy with two coats...if this second one will ever dry.
jeff...
User not found
MTCW,
Dave, I have yet to meet any brand of varnish that I would recommend to anyone. Polycrylic man - try it you'll like it
Done that, and do :icon_thum But for this application I like the concept of the long oil varnishes for flexibility as this wood expands and contracts with the seasonal humidity fluctuations. Plus the added UV resistance is a plus.
You may want to thin it by about 20-25% to see if that helps. It may build a little slower, but if you can put 3 coats on at 1/2 thickness every day it is faster than 1 coat every 3 days.
Makinsawdust
Robert
Dave,
I had the same experience as you with this product on chestnut. Based on experience with their shellac, I was expecting great things from it even though it was less expensive. It's been months since I used it but it seems like it was very thin and "drippie".
