In a much smaller workshop than when I was in Martinsville, but I will be able to make it work.
Equipment did great being stored for that time. Just sprayed the cast iron with that WD40 brand of rust inhibitor that goes on wet and then dries hard.
One coat and covered with that cotton material that you use on furniture to be stored. Seems to keep the moisture away from the cast iron.
Anyway I digress, here is a picture from today and everything but the router table has been checked out, lubed, adjusted, and run. Yes, time for a wine rack project requested by the missus.
Had to go vertical with storage.
Have a few more items to clean off the floor to make room for the router table and get that set up.
Had a company do the concrete floor and block, which helps a ton as it blocks out moisture and humidity in the garage.
Bob
Bob
