I've reached the stage of my workshop where I need to wire it from scratch. I figured I'd think out loud to make sure I'm not missing something.
It's a 12'x20' building that is close to my house and I should only need about 45' of the expensive wire from the main to the lug. The plan is to run 4' from the main to the floor, 11' conduit to get past the concrete patio to dirt, 14' of buried line 2-3' down and then ~9' up to the load center. I'll need to contact the inspector about minimum depth for the buried cable and also about grounding requirements. I really wish there was a national standard for both of those.
How many amps are actually needed for a workshop? I've been planning towards a 60 amp connection from the main to the workshop, but was wondering if it should run a thicker line in case I would need more in the future. How many amps do you guys/gals run to your shops?
I plan on wheeling my DC around as I shift from tool to tool and was thinking about dropping a 230v in each corner to half the amps needed. These will probably be a dedicated series of outlets on a single breaker to cut costs. I'm also thinking about rewiring all possible machines to 230v. It'll also cut down on the amp requirements and help prevent the motors from bogging down (at least that is what the internet tells me). Would the workbench benefit from a 230v outlet, or would that just be an unnecessary expense and sit idle? I can't think of any tools that would go on the bench that would use 230v.
I've read elsewhere that putting outlets at 52" allows resting plywood against the wall without blocking the outlet. I don't plan on laying plywood everywhere , but I can see its value. Outlets that high would inhibit my ability to move tools away from the wall because I'd lose ~3' of cord length with the drop. Less if the tool is on a stand. To address this problem, I was thinking of chaining another outlet down at ~12" for the more common situation where there is no plywood. Should I run the high and low outlets on separate breakers?
I also intend on putting an outlet in the rafters for the air filtration. Should I put more outlets up there for lights, drop cables or some other reason? I do have 4'x12' lofts at each end of the shop. I wonder if I should put the little air compressor up there instead of under the work bench.
I'm not really sure which approach to take for wiring the lights. Is it worth the cost to run another one to two 12/2 or 14/2 lines from the main panel for the workshop lights? That will guarantee that I'm never in the dark if the subpanel circuit goes. It does mean that I could be in the dark with the machines running, but very unlikely. Is it better to connect lights to an outlet or direct wire?
There is an external 115v 15 amp outlet on the house that is only 15' from the side of the workshop, but it is on the same breaker as this computer. Should I wire any external outlets on the workshop? Or would it make more sense to just put a few outlets closer to the doors?
The post is a bit long, but any feedback would be greatly appreciated.
