I was contemplating my naval, when this occured to me.
Why do bench grinder wheels cut in a downward rotation?
I have found it much easier when I grind a chisel, if its held below the center point. Or, if I angle the edge to be cut near the top (say 1 or 2 oclock if you looked at the side of the wheel).
In some digging, I did learn that honing wheels should rotate away from you.
But, I couldn't find a good reason "why" the grinding wheel rotates towards you.
There are factors like the tool rest, safety and burr size.
But, in my mind, if a tool was being pulled away from me, wouldn't that be safer should it slip?
Thanks,
Thanks,
