FWIW, you should be very happy with the Steel City 10" hybrid saw. I have an older (4-years now) Steel City 10" left-tilt [hybrid] cabinet saw. Unlike some, the trunion assembly is cabinet mounted, which makes adjusting the table's parrallelism to the blade quite simple compared to the more common table-mounted trunnion assembly.
If you go with the Steel City, make sure you purchase a model with their higher-end T-fence system, it is well worth the small extra you'll pay for it over the lower-end fence standard with some of their models.
Unless you have a specific need for a right-tilt saw, I would encourage you to seriously consider a left-tilt saw if you have a choice. Bevel cutting and such is easier/safer on a left-tilt saw (you never trap the offcut between the blade and fence with a left-tilt saw), plus you can always keep your fence on the left-hand side of the table which gives you the maximum range, even when bevel cutting panels. Just realize that some commercial jigs and miter gauges have to be disassembled and reverse assembled for left-tilt since they often come setup for right-tilt (it used to be that right-tilt was pretty much all the average consumer had to choose from).
By all means, feel free to purchase used if you prefer or it better fits with your budget. Just don't let fear of setting up a new saw be the determining variable -- the only 'difficult' step IMHO is the initial leveling of your extension tables -- not that big of a deal. Even a used saw needs to be thoroughly checked for proper setup because you can not just assume that the previous owner knew what they were doing when the set theirs up.
