Vise workshop second prototype
pop-pop
Man with many vises
The first prototype vise for next year’s workshop is over at Phil’s shop in beta test. I needed some wood for a second prototype vise to tweak some dimensions and finalize the build sequence.
These painted walnut cabinet doors and drawer fronts are from a kitchen decorative accent project that went south in stages.
After stripping, light planing, and ripping those painted boards are now these 8/4 wide slats.
My plan is to make the wooden components for this second prototype vise by laminating these 8/4 wide slats into a chop, leg, bracket, block, handle, and hand-wheel. The mortises for the X-cross were cut into a slat as shown. Note in the workshop we will most likely make these mortises with a router in solid wood.
The mortise width in the chop and leg is set exactly by the width of these two slats. The mortise depth is slightly shallow and will be made exact later with a router plane.
After gluing, here are the chop and leg blanks complete with maple “racing stripes” for decoration
Here is the set of wooden parts for the second prototype with most of the sawing operations completed. Drilling the various holes is next and I’ll post that later.
pop-pop
pop-pop
Man with many vises
The mortises for the cross arms start with a knife wall and a diagonal saw cut.
and then chopped with a chisel.
A router plane sets the exact depth of the mortises.
Next are the Al bearing strips to prevent the ball bearings from denting the bottom of the mortises.
Drilling the pivot pin holes from both sides after careful layout. Had some nasty breakout from the arm mortise walls so I need to work on that problem. First thought is to drill before mortising.
Test assembly and all is OK. Chop moves smoothly and leg and chop line up.
Next will be the handwheel and screw.
pop-pop
pop-pop
Man with many vises
The handwheel has a counterbore for a dumbbell handle nut on each face. Each nut is modified by drilling and countersinking for three #8 screws. After fastening one nut, the opposite nut must be phased for minimal looseness and then screwed in place. When the phasing is right, with a flip of the handwheel, it will travel for a few inches along the screw.
Here is what the almost done 16” tall prototype #2 vise is looking like:
pop-pop
pop-pop
Man with many vises
Pop-Pop, WOW...the vice is not only useful, it is beautiful!
Thanks!
It looks better than I expected from recycling painted walnut. The hard maple was recycled from bed rails that our grandson outgrew. Avoided a store trip during this year’s pandemic.
Looking forward to meeting you in the workshop next year.
JohnnyR
Looks great. Can I ask what the width is, have to make sure it fits in my front vise.
pop-pop
pop-pop
Man with many vises
The leg is 4-1/2” wide.
The chop is narrowed to 4-1/4” late in the build process so that you can use it in a front vise like this:
The bracket (facing forward above) can also be clamped to the bench front with a pair of C-clamps as an alternative.
pop-pop
pop-pop
Man with many vises
Previously, I have been using a modified piece of Schedule 40 PVC pipe to line the hole in the block and leg that the screw slides through. Today, I replaced that with a pair of 1/4” thick HPDE washers made from a kitchen cutting board.
So far, that works so I decided to stop tinkering and put the vise into service and test it out that way. BTW, the finish is a couple of wipe-on coats of Original Waterlox that I won in the raffle followed by Johnson’s wax applied with steel wool and buffed.
Phil S
Phil Soper
I am SO glad to have the opportunity to host this workshop in June. Mike (pop-pop) is doing an excellent job
I sure wish I didn't live 260+ miles away from Phil's -- I'd love to participate in this workshop or a future one on this topic. Maybe one at Bill Clemmon's shop next time (I can make it there in 2 1/2 hours or so)?
pop-pop
pop-pop
Man with many vises
Maybe a video tutorial could evolve from the workshop?.
I plan on sharing the detailed instructions PDF to the Resources section after the workshop. Building this vise involves standard woodworking operations so I’m not sure that a video would add much value?
Ralrick
Rick
I'd like to be part of the workshop if there is still room available. Great job in documenting with the pictures!
pop-pop
pop-pop
Man with many vises
Made another vise handwheel to evaluate 4-lobe vs. 5-lobe. Decided on an end-grain butcher block glue-up from more bits of reclaimed walnut. A nice bonus of this method is the entire periphery of the handwheel is long grain for better feel and appearance.
