The largest of my two lathes is a Rikon 70-3040. It has a swing of 30." I have been using Record Power SC4 chucks and jaws with no problems. These are well constructed, nominal 4" chucks. However, I have been told that when turning larger, heavier timber, that a larger chuck, possibly a VM120 would be a better match for bigger projects.
The VM120 is a heavier chuck than what I have been using. The jaws have a range of motion of 2," vs 3/4" for my Record Power SC4s. I have the 4" deep gripper jaws and the 5 1/8" dovetail jaws too. Both of which can attach to a large spigot or mortise. I always figured that if I go into massive work, that I would start off with a big faceplate, instead of a chuck, assuming that the 4" deep gripper or the 5 1/8" dovetail jaws would handle the work after the outside of the project had been shaped.
When watching YouTube videos, it appears that most turners are using nominal 4" chucks, with a variety of jaws. So far, I have not seen or heard of a name brand chuck coming apart due to turning heavy or unbalanced timber.
I don't mind springing for the VM120, I just wanted to hear the experience of the woodturning in this forum about whether I should add this chuck to my collection.
Thanks
Thanks
