Last year, I needed some 1/2" cherry stock for a little magazine stand. Rather than planing down the 4/4 stock, I resawed a few pieces, with surprisingly good results. The resawed boards have been lying around since then, until I decided to try veneering some 3/4 plywood. It came out really well! I don't have a drum sander, so I used the ROS to get the veneers down to 1/8" - much thicker than commercial veneers of course. So now I got the veneer bug bad. Right now, I'm using lots of clamps and cauls, I might decide to build a vacuum press if I could figure out where to put it
Anyway, I've found that hardwood is expensive. Cutting them into veneers is certainly economical, but you still need to buy the stock. To save money, I've started to resaw hardwood plywood. I have several leftover half sheets of Home Depot oak- and birch plywood, and although the figure isn't great, it's not bad. I've found that with a little patience, proper tensioning and a good blade (Woodslicer), I can cut the hardwood layer off the plywood very smoothly. It only need a little bit of sanding before gluing it to the 3/4 plywood substrate.
Still, I'm having two problems I could use some help with:
- Since I can only use one side of the plywood veneer, I can't do bookmatching. Does anyone know if Home Depot keeps its cabinet grade plywood sheets in order? If I could buy two sequential plywood sheets, I could resaw them in such a way the veneers match.
- What is the best place to buy other hardwood plywoods, like maple and cherry? Home Depot doesn't carry those, and I'd like to veneer some other species.
Thanks!
Thanks!
