Tool Gloat - A-Line-It
gesiak
I won the big raffle prize at tonight’s Fox Valley Woodworker’s Club meet. Scored an A-LINE-IT DELUXE Machinery/Tool Alignment System w/ 22 Interchangeable Tips, 11 inch Long Anodized Aluminum Bar, Anodized Aluminum Smart Bar, Dial Indicator, Precision Steel Pin and Arbor Run-Out Kit. On a table saw, it will allow you to test table saw alignment, arbor shaft run-out, saw blade run-out, rip fence alignment, and fence straightness, arbor/chuck run-out, jointer/planer head to table parallelism, jointer/planer knife alignment, out-feed table alignment; router/shaper spindle run-out, or any other set up or alignment measurement you desire.
It’s been awhile since I checked the set up on my table saw and drill press. That will get done this weekend.
zargon
Zargon
Good luck with that. Just remember... it's "WOOD" working... not Tool and Die or critical machining ... a couple .000" in metal can be disastrous... wood moves in "inches" not .000"
But... it is always nice to know that if you were cutting 3" steel on your table saw that all the parts would be within a very close tolerance.
Wood on the other hand... wants to expand and contract even after you have meticulously "machined" it to the .000" 🤪👍😎
.... now if I could just keep my band saw cuts from drifting to the north and south poles... 😱😏
jr14
JR
Agree w Zargon. Wood is not a static material, in my experience. Part of its charm, I guess, is allowing for seasonal movement.
gesiak
gesiak
They are useful in determining set up of the tool not the wood. An example of that. Using my drill press to drill pen blanks, I noticed that the hole at the top of the blank was dead center, how ever the bottom hole was off center. Additionally, the hole was slightly oval.
Using the A-Line-It tool from the club library, I noticed that taking a reading at the drill bit just under the chuck varied by +/- .0100. Taking a reading on the shaft showed no variance. Some research indicated that when the chuck was put on the shaft it was on square. Removal and reseating of the chuck eliminated that. Now the holes are center and not oval.
I agree with Mike. You never get accurate results or fit is your tool is not properly set up.
