does anyone know where I can get one of those ratcheting tap handles
Phil, something that I like even better than a ratcheting tap handle is a socket that slips over the end of the tap. My brother gave me a set several years ago, and they are now my preferred method of tapping (unless I require extraordinary precision - then I use the mill or my Ellis drill press for precise alignment).
Among other reasons, you can tap a hole right up against something since you're using a ratchet to drive the socket.
Sears also sells them, but you can find better deals. Here is what I'm talking about.
http://www.sears.com/shc/s/p_10153_...LE01&sid=IAx20090815x000001&aff=Y&origin=prod
In the past I have used a 1/4" drive extension with the socket end lopped off in my drill press chuck. On the end the appropriate 8pt. socket is placed on the tap. These sockets were originally designed for square fasteners which we rarely run into nowadays. The drill press is of course used with the power OFF. :wsmile:
Thanks Scott, that kit looks great and it would work fine if I had alot of tapping to do - but the only thing I have to tap out is my bottle stoppers - I sometimes do the Acrylic stoppers and I need to get a good straight tap on them. I seen a video on how to get a good straight hole/tap and he suggested one of the ratcheting handles.
