Need Some Help
Having a problem getting square cross cuts. Boards have been jointed so the broad and narrow sides of the board are flat against the table and the miter. Each side of the blade appears to be parallel to the edges of the throat-plate recess, at both the front and back positions. Miter gauge is square to the blade.
But when I put a square on the end of the board after I make a cross cut, the leading edge of the board (the edge that enters the blade first) is off by a bit less than 1/32” of an inch compared to the back. Not exactly square. I’ve even allowed for some minor play in the miter gauge to the miter groove by holding the miter tight against one side or the other of the miter groove.
Have checked for wobble in the blade as it circulates but either I'm not noticing it or the movement of the blade is fine. Wondering if the source of the problem is the blade trunnion – haven’t tried to adjust that yet because I’ve never done it before.
Table saw is a Ridgid 10-inch TS3650.
Any ideas?
Any ideas?
