Here's what I do...
About 3 or 4 ounces is about all I mix at one time. This actually goes a long way.
I mix this in a large size pill bottle (about a five or six ounce size) - the kind you get at the pharmacy - the alcohol will not melt these bottles. Your local pharmacist will probably give you a few if you don't take pills!
Measure (liquid measure) 4 ounces of denatured alcohol and put it in the bottle.
Use a postal scale and measure 1 ounce of shellac flakes.
mix this into the alcohol. This makes a two-pound cut - just perfect for French polishing. If you need a three-pound cut, use three ounces of alcohol.
Put the bottle in your pocket and leave it there for about an hour. Your body heat, and the mixing from your movements, will prevent the gum from forming on the bottom. Usually an hour is all it takes and you have enough shellac for a good sized project.
Just mix a small amount and toss it after a couple months - this way you always have fresh shellac - The shelf life of mixed shellac is only about six months.
Matt -
inlaybanding.com
