Just an update.
I ordered and finally used the Delta blade—it’s great. I ripped some 2x SYP and 2x cherry and ended up with a smooth cut line on both. I can’t speak to the cross cutting quality yet, but so far it’s been a great blade for ripping!
Yhakks all!
Jeff, I'm not sure, but are you inferring the Delta is not a good blade?
I'm also comparing this to a frued "glue line" (full kerf) blade--I've also been satisfied with my freud blades. I plan on replacing my thin kerf blades with full kerf blades since upgrading from a contractor saw.
I'm not inferring anything and your new Delta blade works fine for you.
You began with your Freud combination blade and the new Delta blade is a combination blade too. Now you're comparing it to a Freud full kerf glue line rip blade. Apples and oranges so I'm confused again, but there isn't much difference in the prices for any of them.
INMHO, Freud is da bestest of the bestest for the price, i have only been using them for over 20 yrs and do not have a complaint yet. I do not use combo blades, they do a little of everything but none good. dedicated blades soooooooooo much gooder
