Ok...I can never let anything alone... After finishing the first generation of the wood motor from the Steebar plans and almost completely redoing the plans to make them actually to scale, I added my own ideas to the second one I built. I tapered the fins, moved the drive motor to the small center gear and changed the 1 rpm to a 5 rpm motor, added a spark plug, cam and microswitch and now have a working spark plug in the compression stroke...
The end of the plug has a white LED that 'fires' when the piston is inthe compression stroke. You can see it lit inthe picture.
By moving the motor to the center gear, it made the whole assembly run a lot smoother. To keep the 'speed' about the same, I went to a 5 rpm motor (couldn't find a 4 rpm) that actually came from a 'disco ball' motor assembly I found on eBay for 1/4 the price of the first motor. I now have orders for 6 of these. Cool!
