Yeah, Walnut dust gets to me more than any other. Just so NO to brown boogers!take it outside and blast it with your air compressor - Please wear some safety gear, walnut dust can be really nasty stuff.
Use a tack cloth.
Or blow the pores out with clean compressed air.
re: finish - use a oil/varnish finish applied with a cloth, e.g. Formby's (satin) Tung Oil Finish, or mix your own from 1/3 tung oil or boiled linseed oil, 1/3 oil (satin) varnish, 1/3 mineral spirits.
-Mark[/QUOTE
I would add one more step in the following order
Blow off with compressed air
Wipe down with a fast drying thinner or reducer-this will remove any contaminants that could be in the compressed air and will evaporate quick enough to not raise any grain.
The tack cloth should be used just before applying the finish so as to pick up any airborne dust that settles on it after useing the air
Everyone is allergic to some degree as Walnut (any in the Juglans group) contain Juglone a toxic alleopathic compound related to quinone.
I recommend a face mask and a Neti pot to clean your sinus's effectively.. Works like a charm!
What does the dust do to other people that are allergic?
Irritant woods include black locust, cocobolo, ebony, oleander, satinwood, sequoia, and yew.
Sensitzer woods include cypress, balsam fir, beech, birch, elm, greenheart, mahogany, maple, myrtle, redwood, sassafras, spruce, walnut, willow, western red cedar, and teak.
Walnut affects mostly eyes, skin and respiratory system. Hives, watery eyes and difficulty breathing.
For me I would like to add two more to the list of walnut - Difficulty concentrating and forgetting things (feeling spacey) which lasts 2 to 3 days after exposure. Walnut didn't used to affect me at all, then I started noticing most of the affects you listed. The more I worked with it the worse it got, till the last few times when it got so bad I had to stop milling walnut all together. I think I may have been over exposed :dontknow:
For me I would like to add two more to the list of walnut - Difficulty concentrating and forgetting things (feeling spacey) ........ :dontknow:
