After making a chess set this past weekend the wife and I needed a way to finish sanding the knights. Alan made a sanding disk while we were taking the class so copied I his design. I only had 1 small faceplate so I decided to make a faceplate to go with it.
I now have 2 sanding disks I can mount on the lathe. I can keep 2 different grits on them and change them out when needed. There are more pics in my gallery if you want to see more.
http://www.ncwoodworker.net/pp/showgallery.php?cat=2732
Cutting the blank for the faceplate.
Mounting the blank onto my faceplate.
Truing the blank.
Facing it off.
Chamfered the back and removed some excess material.
The final result:
Truing the blank.
Facing it off.
Drilling an 11/16 hole through it.
I removed the blank from the lathe and ran a tap through the faceplate and into the blank. Using the factory made faceplate to make sure the threads were straight.
Removed the faceplate and install the blank directly on the lathe. Turned the outside true and faced it off again.
Marked and cut a scrap piece of cypress for the plate.
Mounted the faceplate onto the plate. After the glue dried for a bit I turned the plate round and faced it off.
The final result:
