If it isn't rotted and is end sealed after cutting, it is still a roll of the dice. If the rings are not fairly circular and symmetric, chance of checking go up. If the rings are widely spaced, you run a higher risk. IMO, your best bet with Bradford is "artsy" turning where a crack isn't the end of the world.
EDIT - I didn't mean for that to sound as negative as it might. By "roll of the dice", I did not mean long shot, just that you will get more loss than with a lot of other woods.
I mean like AnchorSeal on the ends. White or yellow glue diluted 1:1 or less (as in less water) with water will work in a pinch. If you cut a Bradford, or just about any fast growing ornamental, and don't seal it almost immediately it will check.
Where can AnchorSeal be found?
