I have a question about the tool cabinet being on that outside wall.
there was a small 4x16 hole cut through the OSB and the insulation is gone there. Looked like maybe they were going to install a small ac or a vent in the wall.
Should i I take the cabinet down stuff the wall with insulation and patch the hole, then cover the OSB with an air tight seal like plastic or rubber?
We may have hung your nice cabinets without proper preparation, insulating the wall behind them would be a good move. I am also concerned that the right-hand cabinet has only one stud behind it. Let me know if you want to install insulation and frame out the area behind the right side cabinet. I have some insulation we can use.
Nice shop Mike. I like your workbench. Looks like its about as narrow as mine. I've found that to give me all the room I need. In the museum world we have to be really careful about what type of artifacts we place on outside walls no matter how thick the walls are. So I'd definitely get something between your tools and the outside elements.
Im envious! you have a FLOOR!!!
