Powermatic 8" Jointer Model 60 - $750 GONE
TracerRound
Larry
Not mine
Older Model 60 - 8" Jointer. One owner - Runs good though not used much during last 20 years. All original. 1.5 horse power - single phase 115 Volt. Tables will need to be adjusted when relocated. Needs it (now) since last moved (4 years ago). I can no longer see well enough to do it. Original documents included. Located north/west of Winston off Reynolda Road west (near Tobaccoville). Also note, blade guard is not shown in photo and I may not be able to locate (sold w/o unless found). Reason - blade guard was OSHA required as required part of original equipment. Frankly it gets in the way so I took it off when originally purchased. Now you can see what you are doing - keep hands away and you should operator should be fine.
bob vaughan
Bob Vaughan
Its not real hard to move. Back in the day I used to move them by myself.
Remove the fence and bracket
slide machine out to van or truck
remove three 3/8" bolts holding machine to stand
tilt machine and roll off belt
start to slide machine into van or truck sideways resting on the outfeed table.
When jointer's outfeed table is halfway in, roll jointer upside down and slide the rest of the way in.
lift stand and motor into vehicle.
