Power Feeder Mounting/Install
Jeremy Scuteri
Jeremy
I picked up this power feeder at an auction a while back, before the new house and the basement shop build, so this was a few years ago. I finally drilled and tapped the holes in the shaper table and put it in place. I went with 7/16-20 bolts, I could have used 1/2" instead, but I figured a little extra room for alignment error might come in handy.
I drilled 1/8" holes followed by 5/32" holes before the final 25/64" holes for the 7/16-20 tap.
Bolted the mounting bracket to the table using the newly tapped holes.
Power feeder in place. My wife helped me lift get it in place. I said "this is the last time I will ask you to help me move this power feeder". It has been moved around a bunch of times.....
A little adjustment to put it in place. It has hand wheels for lateral and vertical movement of the head which is nice.
I need to replace the missing piece that tightens the base to the column. A bolt will work until I find a replacement. The manufacturer replacement part isn't available, but I should be able to find something.
The power feeder has forward and reverse with 4 total speeds. I haven't used it yet, I need to take my time to get things setup properly. It will be interesting to see the difference in cut quality compared to what I would get hand feeding on a router table.
https://photos.google.com/u/0/photo/AF1QipMXU1NcVLg5aO623nw2Sgh-ndjd9tzoGQEJWimm
Michael Mathews
Michael
Jeremy, I picked up a misc. box of large T-bolts with heavy shoulders at an estate sale several years ago. If you can post what the bolt length from tip to shoulder needs to be along with the thread size, I'll check the box. Also note if there's a clearance required for the T to clear the frame.
BTW, looks impressive!
chris_goris
They take a few minutes to setup, but once you do, youll be amazed at the quality you get from using a powerfeed. I rarely use my shaper without mine anymore. The only thing you have to tweak generally , is your outfeed fence distance relative to the infeed. It needs to be set slightly back. This typically causes some snipe but I never run lengths cut to size anyhow. Where did you get that feeder? It looks like my old one!!. One other tip, replace the drive wheels, they get old and hard and dont grip the wood. Grizzly sells them reasonably.
chris_goris
Ive got some extra T bolts at home, Ill see if any of them fit that base. or this:
blackhawk
Brad
I've never used a power feeder, but just wondered if they have tapered rollers or a tracking adjustment to be sure that the wood is always pushed against the fence as it is fed.
Rwe2156
DrBob
Very nice addition. I think every shaper should have one.
Mine isn't as big, I mounted it to a board, which is in turn screwed into inserts in my router table. Only because I'm hoping to come up with a way to use in on the table saw.
Jeremy Scuteri
Jeremy Scuteri
Jeremy
I got it at an IRS Auction for $275. It's a 220V unit. I figured that was worth it just to check it out. It wasn't too long after your sold yours, that gives you an idea of how long ago this was (and how many times it has been moved around and been in the way). If I remember correctly you switched to a 120V Powermatic?
Jeremy Scuteri
Jeremy Scuteri
Jeremy
Like Jack (Skymaster) said above, you angle the power feeder towards the fence (toe-in). That keeps the stock pushed down to the table and against the fence. Even and consistent pressure and feed rate.
Willemjm
Willem
Nice job Jeremy!
Interesting there are no rules for which side of the shaper the power feeder should be mounted. Mine is mounted on the left side on both my shapers.
I use two feather boards to keep things against the fence.
chris_goris
Yes mine is a 120v PM 4 roller, 1HP. Those things are horrible to move around!.
bob vaughan
Bob Vaughan
The placement of that base is probably the best for versatility.
When you can, pick up an extra extension and move the fence 90º. You'll be amazed at the convenience of having that extra length of bed under your stock when doing long work. Also, for convenience, put an auxiliary starter button where it can be easily used with the new fence position. I use my shaper this way 98% of the time. I've also learned that a shop made fence is far superior to the factory fence in many ways. I also use the shop-made fence 98% of the time. Some examples below.
Doing some custom hand rail.
Doing some custom casing out of walnut
Two start-stop stations for convenience.
chris_goris
/QUOTE]
Ive found this fence to be very robust and user friendly. the only thing ever have done is add a continuous fence for raising panels.
