I'm getting ready to do a project that's been back burner for a while now and I have several questions for the group.
First the setting- the existing porch ceiling was done in drywall with a textured paint finish. No priming was done which is evident as when the textured paint comes down in sheets.
Goal- I'd like to do a T&G wood ceiling, species TBD ( that's one of the questions)
The questions-
Finish- painted or natural, I've seen both and painted seems more common/ traditional but depending on species I could go either way.
Any pros/cons other than appearance?
Species- I'm a fan of cypress especially with a natural finish. Probably wouldn't go that way if I'm going to paint. Any reason not just to go with pine if its painted? Other varieties to consider?
Sources- any rec's? What ever I use I'd like it to be milled and ready to go. T&G, beaded.
Thickness- It's a ceiling, what's typical for this kind of application?
Finish- should I seal the back before I put it up or just finish what's exposed?
Prep- The simplest thing would be to just strip the loose paint and go over the existing drywall, but that seems like a shortcut I may regret. Thoughts?
Orientation- long way or short way? Most I see are oriented the long way which would make sense if I've torn down the drywall. If I leave it, why not go short way?
Sorry for all the questions- I've finally gotten off the dime on this and want to be ready to roll when the weather gets nicer.
The questions-
