This might be just a crazy idea, but I use plywood a lot, it’s stable, cheaper than hard wood and easier to fine in most cases. I have been using a lock miter bit which works great with grain but perpendicular to the grain it chips out like crazy. I and also interested in doing dovetails and other joints. I plan on getting the edge banding kit to put hardwood edges on the exposed plywood edges, mainly like the look better than a thin piece of veneer, although I have veneered a lot of plywood edges.
I was wonder if it makes any sense to put a hardwood edge on the plywood then cut the lock miter of dovetails or whatever in the hard wood, I would think with dovetails that would be the only choice if it was going to be exposed. Just wondering if his would be a waste of time. I am sure if the grain matched and you were to use a pre stain conditioner you would get a pretty good looking panel. Just wondering if I am way of base or if it is worth trying.
