I'm looking for an informed opinion here: The leak appears to have stopped on it's own. It's been almost 24 hours and no new drops have formed at the joint. Should I still take it apart and attempt to make it better, or leave well enough alone?
As I posted earlier, I found out Friday that we have 180 PSI of water pressure coming into our house with no pressure reduction, so I installed a pressure reducer on Saturday. I also replaced the old shut off valve with a ball valve and installed a union so I could take everything apart more easily if need be.
The problem is that I keep having minor leaks on the street side of the reducer. I think I finally have everything water tight except the union (see photo). It's cranked down as far as it will go and it still has a slow drip - one drop every 20-30 mins. So I have questions:
Was there supposed to be a gasket with the union? There doesn't appear to be a seat for one.
Should I not have used Teflon tape at the union?
Is 180 PSI too much pressure for Teflon tape? For a 3/4" brass union?
Should I use dope instead?
HELP!
