I think I want to mount a router in my table saw. I would appreciate advice and guidance in at least two subjects.
1) Which router;
a) Freud 2000E, a 3 1/4 hp 15 amp plunge router, 13 lbs but no height control from the top
b) Craftsmen 2 1/5 hp, 12 amp 9 lbs. comes with two bases and does have a heights control form the top.
Both are variable speed but you have access only at the router meaning I have to bend down and stick my hand under the table or pull the router up through the table.
Next issue is mounting it in the table saw. Should I put in a cast wing that replaces the existing wing? Should I put it in the side extension table? Should I use an aluminum plate? Does a cover box underneath help with noise and/or dust collection?
Is there a good fence that will attach to the Biesmiere fence?
All thoughts and constructive comments appreciated.
1) Which router;
