Not Ready 4 Scrap Pile Follies
LeftyTom
Tom
I read the posts where some members were having good luck finding uses for leftover wood, so I thought I would give it a go. I've been meaning to build a mobile stand for my planer, and a quick measure of leftover ply found I had 23 pieces just the right size for my sides. I cut my top & back to size, and got me some casters and a couple of 2x4's (splicing 12" & 15" scraps together seemed cheap, which is a lot coming from me :rolleyes: ). I put in some brackets I scavenged from some pallets at work, and I gotta get me a shelf and a bottom from my leftover-leftover ply. I dunno if I want to put a door on it, but here are the required pics......
TracyP
Tracy
That is an excellent use of scraps. You got a stand for your planer and gained some space for some more scraps!!
ScottM
They are not scraps. Consider them wood that has not found a project to call it's own. :gar-Bi
That's my next build, right now my planer is sitting on the floor, when I need it, it goes on a board across saw horses. I was going to build a nice cabinet, but I have some scrap to use up myself.
If it's big enough my shop vac can't vacuum it up, it's not scrap. It's stock! Good looking stand, that should serve you well. I recommend a door, or whatever you're storing on the shelf will be covered with dust and shavings.
JackLeg
Reggie
Tom: We're thinking similar thoughts. In this month's issue of Woodworker's Journal, Page 58, is a mobile shop table with multi uses. I picked up the casters tonight at HF in Kannapolis.
This just might be my rainy day project tomorrow!
Yours is looking good!
:wwink:
sawduster
Robert
Man I love it when [strike]scraps[/strike] offcuts find their rightful place :eusa_clap
Good job :icon_thum
sure wish I knew how to build something :BangHead:
I tend to just make more [strike]scraps[/strike] offcuts :gar-La;
LeftyTom
Tom
You know how things conspire against you, so nothing goes as planned? Well, I ran out of ply (not even enough to piece together for a door), ran out of woodscrews.....shoot, I even went thru the hardware saved from a good 18 years ago, and could not even find sheet metal screws to install the shelf and bottom! :BangHead: What's a WW'er do in stressful times like this? :help:
I am so ashamed....:XXfridge:
CaptnA
Andy
Outstanding piece. And all the better for the ingenious use of 'parts'.
In my line of work we call that- 'utilization of available resources' and I teach that sort of thing as a management technique in fire department leadership classes.
BAS I'm with ya, my vac can't ingest stock. Everything else is waste
unless I need it for filling by mixing with ca
