I have an old Disston D-8 saw with a broken horn that was my grandfathers.
Rather that trying to just glue-on and shape the missing part, I decided to make a new saw tote.
A friend donated a chunk of mahogany. Here is blow by blow description of the process.
First I roughed in the blank to size and split it in half using the bandsaw:
(You can see the old apple wood handle sitting there in back.) I used a router plane to remove a kerf-width worth of wood in the shape of the blade - and drilled some reference holes:
The reference holes allowed me to reestablish the blade outline once the two halved were glued-up:
I made some relief cuts with a back-saw, drilled out all of the circular features using forstner bits, and roughed in the shape using a turning saw:
Then I coped out the hand grip and now it is time for the rasp:
(In the background is the handle from different saw - I liked the shaped of this one and how it felt in my hand - so I reproduced the blade side from the broken D-8 tote, and the grip side from this one).
After removing everything that didn't look like a saw tote :gar-Bi and working my way though some sandpaper grits, I drilled out holes for the fasteners.After around 3 hours of shaping, I ended up with:
I've finished it off with some boiled linseed oil, a few coats of shellac, and some paste wax. Now I just have to figure out how to sharpen a cross-cut saw!
Andrew
Andrew
