I ordered a Delta T2 fence to replace the OEM fence that came with my R4511 table saw.
The original fence has gotten me by, but it has never been totally satisfactory because of the split rail design that tends to flex whenever the fence is locked down across the split rails. Just a bad design because of the weak point.
The T2 rails, fence, and tube seem solid as a rock and should be a welcome addition once I can get them mounted.
It looks like I'll have to drill some holes in the T2 front and rear rail as only two out of the 4 holes line up, and if I used those the tube scale would have to be replaced. If I can I'm going to try and drill the holes so that the tube will fall in the same place as the original.
If that doesn't work out then I'll have to get a replacement tape. Haven't used the drill press in a while, so time to re hone those machinist skills.
