After about two months of very hard work, ~
75% by myself, I am ready to pour the concrete for my first workshop and/or man cave. I've been wanting to post for quite a while, but wanted to wait until I had something more substantive to show. Here you go!
floorplan layout:
3D design:
virgin soil:
building the retaining wall for leveling the back yard:
Starting to build up the ground for the slab:
View image in gallery
floorplan layout:
3D design:
virgin soil:
Had to dump piles of dirt and spread out by hand because trying to level with the bucket just dug the tires into the sand...ruining the base for the slab. Ended up spreading 3-4 inch layers by rake and then compacted with plate compactor.
An unbelievable amount of work up until this point:
What's missing here is about a month of framing up the concrete forms....very hard work, very precise. My forms are only about two string diameters off in elevation, and no more than an 1/4 inch off in L or W, and not more than 1/4 off square.
Finally starting the plumbing:
Careful placement of the building drain lines:
In case you missed it, this is quite the footer!
Getting the rebar placed in (bending rebar is definitely worth the $200 bender if you're doing steps in the foundation, or anything other than 90 degree bends; note: I did not and spent many frustrating moments trying to bend rebar in z-patterns, with mixed success)
This straight run turned out pretty well: (luckily for me, my wonderful wife was kind enough to help me tie these together and tie them to the anchor bolts; note: It's a lot tighter than it looks, so if you're not a small guy, better get yourself a petite lady friend to help with this step))
Wrapped and ready to go!! (minus cutting off the 2x4 excess above the plywood)
