Would you believe a six-hundred dollar planer with not feed tables!? I sold off my 15 year old HD Ridgid and went for the Two-speed, Three-blade DeWalt thinking 'upgrade.'
Then I discover the feed tables that come with the $369 Ridgid are an extra, special-order item (at Lowes).
While researching the 'problem,' I thought I saw a post and picture of a stand built to fit the planer such that the planer fit in a recess in the stand and the 'top' of the stand at either end served as the feed tables and supports (much like when folks build their Miter Saw into a work bench such that the top of the Miter Saw is in the same plane as the top of the bench.
Of course, I can't find it now that I own the planer!
I saw "Home » Member » merrill77 » Planer Stand" for a 15" HD Planer, but it appears much larger than I hope to build with feed supports than look to be several feet long (both In and Out!).
If anyone has built such a stand, I would appreciate seeing an image or two and possibly chatting him or her up as to the design and construction details.
On a side note, seeing the various posts here on building mobile stands, may I suggest watching HFT for sales on their Furniture Dollies. I've purchased the small one for as little as six-dollars (w/25% Off coupon) which is less then the price of the four casters! I used one for my Disc/Belt Sander combination with slight modification intending to finish it up elegantly 'down the road.' Way down the road now and, well, it works fine as-is!
And, if you can score (Asheville Scroungers' Paradise) an old shopping cart that was not terribly abused, the rear wheels on them are ideal for making heavy equipment stands that raise up to move the tool and lower to use the tool. Their brackets are offset enough to allow mounting them (t rear of tool) with the wheels just touching the floor so that, raising the front onto two swiveling casters allows easy movement of a heavy tool (I did it on a Table Saw and on a RAS.
