I need an accurate miter gauge at a reasonable price. Any recommendations?
What Bas says.....dittoSteve was gracious enough to give me his JessEm Mite-R-Excel. :notworthy:I've had it for a while now, long enough to give you my opinion on it.
This miter gauge is extremely well constructed. It feels very solid, with large, knurled brass knobs. It is heavy, providing a lot of stability when sliding it across the table. The stop and extension are convenient, as is the adjustable scale. Angles can be set at 0.5 degree increments. It takes a little getting used to, but it's pretty simple to figure out after a few uses. I don't know which part was off (most likely the table saw), but I found I was able to cut perfect miters with one end at 45 and the other at 44.5.
The bad thing is that the miter gauge is heavy and solid. It is not something you just hang from a pegboard or lift with one hand. With limited room in the shop, I find I'm always searching for a place to put it. The only thing that hasn't worked too well is the miter bar adjustment. It has allen screws so you can adjust the width, but at its narrowest setting it barely fits my table saw. Plus, one was stuck so tight I nearly stripped it. All in all, very minor problems.
I've used my crosscut sled a whole lot less since I got this miter gauge. But, you asked about affordable. Would I pay $250 for it? No. I don't think it's that good. I have seen the Incra 1000SE. If I were to buy a miter gauge, that's the one I'd get. The JessEm is the better gauge, but not by much, and certainly not for that kind of money.
Of course, if someone offers you one for free..... :gar-Bi
